Vibration in OD???
Old Mar 24, 2011 | 11:35 PM
claude1991's Avatar
Default Vibration in OD???
So my car is finally legally on the road
However, I noticed at highway speeds (IE, right after OD engages 45-50MPH) I get a vibration in the car. Not super bad, but very noticeable. Goes away when I just shift it into drive.
I have not changed the tranny fluid yet, which is fairly dark. I am guessing that should be my first step? Should I put any type of cleaners into it before I do the pan drop? Any fluid recommendation? I was thinking of Valvoline Maxlife.
I also have not replaced the gear oil yet, but I didn't think that would effect this specifically. Gear oil is kinda icky looking, but I don't think I have ever seen gear oil that wasn't lol.
Thanks guys,
Claude
Old Mar 25, 2011 | 01:26 PM
When the transmission shifts to OD the engine has to work harder (larger throttle opening & lower RPM) to maintain road speed. Although this increases fuel economy it also increases engine load. Engines under load are more prone to misfire. Try replacing plugs and wires first, before messing with the transmission. I seriously doubt that changing transmission fluid will help your problem.
Old Mar 25, 2011 | 02:09 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
jus tell the women its for them =]
but no seriously change your plugs and wires lol possibly a full tune up
Old Mar 25, 2011 | 05:14 PM
claude1991's Avatar
OK, I was about to do that as well. Seafoam it, plugs wires, ect ect.
@DK lmao
Old Mar 25, 2011 | 05:53 PM
I would hold off on the Sea Foam and use some single purpose injector cleaner, such a Techron.
Old Mar 25, 2011 | 09:15 PM
claude1991's Avatar
I put that in the fuel tank as soon as I got it. Autozone had buy 1 get 1 free!
I was going to suck the seafoam in using a vacuum line, not in the fuel.
Old Mar 27, 2011 | 10:39 PM
claude1991's Avatar
Just wanted to let you guys know what it was. While replacing the plugs and wires (and the wires were like welded on to the plugs, tore all the wires trying to get them off), I noticed cylinder no. 2's fuel injector was unplugged
Once that was plugged back in, it already was a heck of a lot betterI have a hunch, the place I took it to, to have the brakes done did it. It really started running crappy right after that, and they were saying it was my CAI (and that they couldn't find the a MAF sensor). Because I know they were all plugged in, when I swapped the injectors.
So yes, sad that I was not able to diagnose that at first, but oh well I guess.
Now I just gotta figure out why cruise control is not working...
2SS_Nate
Jun 8, 2012 10:30 PM
wiebes11
Sep 23, 2011 09:05 AM
zapperdan
70-81 V8 Tech
Oct 14, 2009 02:59 PM
robs93z28
Oct 11, 2009 10:54 PM
1stgenssclone
Jan 2, 2008 11:24 PM
