vibration
Old Jan 1, 2008 | 06:16 PM
1stgenssclone's Avatar
Default vibration
got a vibration in the 68 about 60 mph
replaced the drive line with new one "universals to'
factory engine mounts, and trans to
when turning a corner though i noticed the rearend making a noise
its somthing like this rrrr rrrr rrrr like a seal barking
left or right, could this be it?
the clutches in the ten bolt warn out and giving me the vibration
need some help!
Old Jan 1, 2008 | 06:32 PM
Ircyklops's Avatar
Default RE: vibration
It most likely sounds like a bad rearaxle bearing, but If you have positraction (and even if you don't), then you might need to change the rear end oil and be sure to put the specialpositaction additive in. The additive works wonders and can elimate "chatter" in the rear end (especially when turning). You can get the additive at most parts stores. I prefer the GM one that can be bought at most dealerships.
Old Jan 2, 2008 | 08:49 AM
THE AXLE WAS LEAKING AND PULLED IT OUT AND FIXED THE SEAL THE AXLES LOOK GREAT WHERE THE BEARING IS RIDING ON IT.
HAS NEW REAR DIF FLUID BUT HAVE NOT PUT THE ADITIVE IN YET.
I KNOW THE ENGINE IS NOT CREATING THE VIBRATION BECAUSE WHEN U FREE REV IT THE CAR HAS NO VIBRATION, IT IS SMOOTH.
MABY GOT A WHEEL OUT OF BALLANCE, OR A REAR BRAKE DRUM OUT OF ROUND
BUT QUITE SURE IT IS COMING FROM THE REAREND.
WILL HAVE WHEELS CHECKED AND THEN WILL POST BACK.
THANKS FOR THE REPLY!
Old Jan 2, 2008 | 11:24 PM
firebird69racer's Avatar
have them check to see ifany of the wheels are bent, I had that prob. once
also check the driveshaft and see if the u-joints are phased right. I know on my Firebird the u-joints are phased out of time just a little. I asked my driveshaft guy about it and he told me the factory did it to keep vib's down. Not sure if Camaros were done the same or not
Let us know what you find out
2SS_Nate
Jun 8, 2012 10:30 PM
wiebes11
Sep 23, 2011 09:05 AM
claude1991
Mar 27, 2011 10:39 PM
zapperdan
70-81 V8 Tech
Oct 14, 2009 02:59 PM
robs93z28
Oct 11, 2009 10:54 PM
