harmonic damper?
Old Nov 17, 2007 | 07:20 PM
hipirn's Avatar
Default harmonic damper?
Am restoring a 67 RS SS convt. from a pile of pieces that's been apart for 25 years, there are pieces from 4 different engines in the mix, the original is the 295/350 which is about back together. the harmonic damper is the issue, in the parts I have there is a 6-1/4" rubber dampened one, the other isa small steel hub about 4" in diameter, both accept the 3 pulley arrangement I need. There are two timing chain/cam covers, one appears to fit with the steel hub damper and has two timing tabs on it, one above the other. The other oneappears to be made for an 8" damper as the pointer is about1 1/2" away from the 6-1/4" damper when both areinstalled on the engine. Both the steel hub and the 6-1/4" have the timing mark over the keyway! Is the steel hub correct for the 67 application?? In looking for parts I don't see any listings for a 67- 350 damper?...hipirn
Old Nov 21, 2007 | 11:46 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: harmonic damper?
See if this link doesn't help in your search.
I dont know the answer for sure so , I hope this helps.
http://www.rickscamaros.com/product....dept%5Fid=3220
Old Nov 21, 2007 | 09:25 PM
hipirn's Avatar
Thanks cplthomas; I have dealt with Ricks and sentthere techs. an e mail regarding the harmonic damper. hipirn
VALHAR
Nov 15, 2014 08:58 PM
tyler_caz18
70-81 V8 Tech
Feb 17, 2014 08:08 PM
baarf
82-92 V8 Tech
Jul 30, 2010 10:31 PM
jarrod1875
LS Series Tech
Oct 29, 2009 12:45 PM
hipirn
Dec 1, 2007 04:15 PM
