big block electric fan
Old Apr 30, 2007 | 12:05 AM
72ponyeater's Avatar
Default big block electric fan
I have a 72 with a 396 with manual trans. I estimate HP at 450. Am wanting to use electric fans for cooling. I want to keep A/C too. Any help?
Old Apr 30, 2007 | 11:02 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: big block electric fan
Sure, there is plenty of help here. I am not sure what you are asking though. You could use an electric fan. If you turn off the A/C or remove the belt from it (if it has a dedicated pully) you could ..... uh.....wake the motor up some.
Old Apr 30, 2007 | 11:27 AM
74454bb's Avatar
May 2007 ROTM
You could just remove the fan and use the electric fans, but if you are keeping the AC why remove the fans? the ac unit will suck up a lot more power then the fan, just install a flex a lite fan with a 1" spacer.
Old Apr 30, 2007 | 06:11 PM
I want to remove the water pump fan altogether. I found a Flex a Lite kit that works for my application. Thanks.
snopro_16
67-69 V8 Tech
14
Aug 23, 2022 04:08 PM
tecumseh
Mar 8, 2011 01:01 PM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
Carinhas
67-69 V8 Tech
13
Aug 23, 2007 05:02 PM
