'67 Camaro Big Block
Old Sep 6, 2005 | 04:21 PM
Booder's Avatar
Default '67 Camaro Big Block
Just bought a very nice '67 SS with a big block and have a couple questions. The motor has roller rockers requiring tall valve covers. The wiper motor cannot be mounted due to the tall covers, any experience in getting around this? Also, the car has 3.93 gearing in the rearend and turns about 3k at 55 mph. Would I benefit from a 700R4 or should I just change the rearend. The car has a beefed up turbo 350 presently. Thanks!!
Old Sep 6, 2005 | 08:51 PM
aaronsirocz's Avatar
Default RE: '67 Camaro Big Block
i would just change the gears, and keep the th350 in it
Old Sep 7, 2005 | 12:15 AM
69rat's Avatar
i agree. keep the th350. a big block would kill a 700r4 quickly. i have a 69 with a BBC (assuming the motors are in the same location) before i took the wiper motor out, it all fit together and i have roller rockers but the valve covers aren't very tall. they are moroso's.
Old Sep 7, 2005 | 12:23 AM
MHC68's Avatar
congratulations on your new toy. i don't know much about the big block clearence problem but i would like to suggest a Gear Vendor's overdrive unit. with this bolt on you can keep the bullet proof TH350 and still run it on the highway with the 3.93:1 final gear ratio. i believe you will have to cut your driveshaft or buy a new one, but it won't be all that big of a deal and would be a pretty cool modification. i have seen a few Year One restored first gen camaros use these units.
Old Sep 8, 2005 | 02:50 AM
69rat's Avatar
wow thats funny you mention gear vendors. i used to work there for 4 years. i assembled all the new over drives we shipped out.
Old Sep 16, 2005 | 03:43 AM
68maro's Avatar
Depends what kind of driving your going to do and your budget, if your going to drive it alot I would go with an overdrive transmission. Theres companies out there making beefed up overdrive trannys. Although they are not cheap. As for the wiper motor they sell some slim wiper motors for clearance problems. Unfortunately I dont remember the manufacture.
snopro_16
67-69 V8 Tech
14
Aug 23, 2022 04:08 PM
Johndeere/chevy
Nov 3, 2011 11:31 AM
tecumseh
Mar 8, 2011 01:01 PM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
