68 camaro block
Old Nov 2, 2011 | 03:14 PM
Johndeere/chevy's Avatar
Default 68 camaro block
Trying to determine motor displacement 68 camaro base vin on motor gone, blank at the pad, block casting #3914678 the same as the 302 and the 350 and 350hp 327 ? is there a another way to idenify .the heads and manifolds are number with casting # of 68 327/350 , the only thing out of place is the 69 corvette rochecter carb ,
Old Nov 2, 2011 | 04:09 PM
Is this a complete engine? If so, you can measure the stroke of the piston. If it's a bare block, it doesn't have a displacement, since the same casting was used for a 302, 327, and 350, all with a 4" bore. The internals (crank, pistons & rods) determine the displacement.
Old Nov 3, 2011 | 06:54 AM
Default block ID
Yes, it is a complete good running engine in the car , then if I pulled a head and checked the bore is about the only way at this point ?
Thanks for the help
Old Nov 3, 2011 | 10:40 AM
It's a 4" bore block, regardless. With the head off, turn the engine over till a piston goes to the very bottom of the bore (pick a piston, any piston). Measure from the top of the piston up to the deck of the block to determine your stroke. 3.48"= a 350. 3.25"= a 327. 3"= a 302. If you don't want to remove the head, you can remove a spark plug, find TDC on one piston, stick a stiff wire (coat hanger, etc) or small dowel rod down till it rests on the piston, and make a reference mark on the rod. Then bring that piston to BDC and make another reference mark. Measure between the marks, and that's your stroke.
Old Nov 3, 2011 | 11:31 AM
GREAT thanks a lot !!!
snopro_16
67-69 V8 Tech
14
Aug 23, 2022 04:08 PM
Horodtim
Jan 28, 2012 09:39 AM
tecumseh
Mar 8, 2011 01:01 PM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
