Convert manual to power brakes...
Old Oct 30, 2009 | 08:16 PM
hubbardgd's Avatar
Talking Convert manual to power brakes...
I have a '68 base convertible with manual drum brakes. I'm looking at converting to power brakes. It looks like I can use the existing master cylinder and add a power booster. Is there any reason I can't use the existing master cylinder? I checked the application code for the master cylinder and the manual and power were the same. I'm not planning to do disc brakes yet, just convert to power brakes.
Old Oct 30, 2009 | 10:23 PM
Pretty much that's all. You will need a different operating rod between the booster and the brake pedal. Someone sells an adjustable one, but I can't remember who it is?
I did this swap on my '71 Camaro, and it took all of a couple hours.
Old Oct 31, 2009 | 07:18 PM
hubbardgd's Avatar
Question
Thanks for the information. Did you have any trouble moving the brake lines out to accommodate the extra distance from the firewall that the booster caused for the master cylinder?
jakejg
Sep 26, 2008 10:33 PM
V6Cam2000
Oct 25, 2007 09:44 AM
nberrios5
Jul 5, 2007 06:17 PM
XFaded
Dec 31, 2006 03:00 PM
hoover
Oct 1, 2006 08:25 AM
