LT1/LT4 Tech 1993-1997
Is it possible/worth it to convert a automatic 96 z28 to a manual?
Old Jul 4, 2007 | 10:22 PM
nberrios5's Avatar
Default Is it possible/worth it to convert a automatic 96 z28 to a manual?
How much?
is it even worth it?
Old Jul 4, 2007 | 11:24 PM
95slvrZ28's Avatar
Default RE: Is it possible/worth it to convert a automatic 96 z28 to a manual?
Not worth it, your first gear in the auto is more aggressive than the first in the manual anyway, and especially if you drop in some more aggressive gears in the rear end, you'll be a manual killing machine on the strip. Just leave it how it is.
Old Jul 5, 2007 | 08:07 AM
JD1969's Avatar
And a higher stall torque converter.
Old Jul 5, 2007 | 03:19 PM
I really don't think it worth the trouble, unless you really want to stir your own gears. But if you really want to do it, the May 2007 issue of GM High-Tech Performance has a big write up on how to go about it.
http://www.gmhightechperformance.com/tech/0705gm_transmission_swap/index.html
Old Jul 5, 2007 | 06:17 PM
Lee Willis's Avatar
You can do anything if you spend enough money, talent, and time.
Why would you want to? If you want to convert an auto to manual, sell or trade the car on one with the transmission you want. It will be much cheaper.
MDThomas26
Apr 14, 2012 03:12 PM
hubbardgd
Oct 31, 2009 07:18 PM
jakejg
Sep 26, 2008 10:33 PM
V6Cam2000
Oct 25, 2007 09:44 AM
XFaded
Dec 31, 2006 03:00 PM
