Appears to run hot?
Old Oct 14, 2018 | 06:21 PM
  #21
Jacouncil3's Avatar
Was even thinking of using this one 45° angle housing but dont think the hose will fit
Old Oct 15, 2018 | 10:56 PM
  #22
I was going to suggest that very neck, then you can swivel it clockwise until you can clear the fitting. I doubt your current hose will fit, but I'll bet you can find one with the right size and configuration. Just ask your local parts store guy to let you hunt through their inventory.
Old Oct 16, 2018 | 05:16 AM
  #23
flat tire's Avatar
once you get the neck clocked where you want it , take a metal cloths hanger and shape it to the outer most points of the neck and radiator. that will give you SOME idea of what to look for
Old Oct 21, 2018 | 08:23 PM
  #24
Jacouncil3's Avatar
Can anyone tell me what the normal temp and max temp for the sensor in the head between cyl 1 & 3? I know its hotter there, just use to see temps around 180/190 not 200+ on these motors
Old Oct 21, 2018 | 08:40 PM
  #25
The answer is, it depends. My first 69, many years ago, was basically a stock 307 with headers. That engine wouldn't go above 180, with the gauge sensor in the head. What temperature thermostat are you running? Out of curiosity, have you checked your ignition timing? Too far retarded or advanced can make the engine run hotter. 200 isn't what I'd consider "too hot", but hotter than I expect it to be. Under what driving conditions does it get there, in traffic or open road?
Old Oct 21, 2018 | 09:00 PM
  #26
Jacouncil3's Avatar
I haven't pulled the tstat yet, using an infrared temp guage most points are 170/180. Timing is set at 12° advance. East Bay, CA and i pretty much just drive local. Its cleaner having the temp sensor on the head, but would like to know temp feeding at tstat.
T10098
Dec 31, 2019 07:24 AM
ChevyManCam
Jun 8, 2011 09:23 AM
Turbolag86
Jan 5, 2011 09:04 AM
afar95camaro
May 17, 2007 09:13 PM
bluovlh8er
May 16, 2007 08:51 PM
