replace ignition cylinder
Old Mar 4, 2012 | 01:05 AM
NOLAcamaro's Avatar
Default replace ignition cylinder
Does anyone know how to change the ignition cylinder in a 2011 camaro (manual transmission). I can order a cylinder but im not sure how to change it out without disrupting the electronics. I also have to make the cylinder fit the key.
has anyone done this? A step by step guide would be helpful but I will take any advice.
Old Mar 4, 2012 | 11:19 AM
You have a new car which is probably still under warranty, why do you want to change the lock cylinder.
Old Mar 5, 2012 | 08:28 AM
NOLAcamaro's Avatar
I left the car for 20 minutes unlocked and someone came by and tried to start the ignition with a screw driver. The result is that the cylinder thinks the key is in it all the time. I can still start the car and it works fine but remote entry system won't work as long as it thinks the key is in the ignition. Its not a huge problem but not covered by warranty and if I can fix it myself I would like to try. Any ideas?
auto
Sep 10, 2012 08:39 PM
Wyo77camaro
Nov 21, 2009 03:22 PM
rwing7486
Jun 16, 2006 02:31 PM
thedvsone21
Jan 7, 2006 04:15 PM
RieskeKR
Jul 18, 2005 06:55 PM
