Fuel in oilpan???
Old Nov 17, 2009 | 09:01 AM
tattooedtrash's Avatar
Default Fuel in oilpan???
i have an 86 IROC 305 carbeurated. mechanical fuel pump and i'm getting gas in the oil. any suggestions?
Old Nov 17, 2009 | 09:05 AM
Your carburetor is running way rich, or your piston rings are fitting like slop. Is your engine a smoker?
Old Nov 18, 2009 | 08:29 AM
it doesnt smoke a bit or use a drop of oil
Old Nov 18, 2009 | 02:15 PM
Check the mechanical fuel pump for a leaky diaphragm, the fuel can dribble into the engine via the pushrod opening.
Old Nov 20, 2009 | 09:56 AM
seosecrets's Avatar
either because of the stock valve covers. They don't look like aftermarket Or maybe if you hear a ring you can turn the key on and let the fuel pump prime it self then start the car if its getting louder then i would definetly replace the fuel pump.
Old Nov 20, 2009 | 04:37 PM
^ Cram your spam up your can, man!
Old Nov 20, 2009 | 05:29 PM
Do you have any idea of what you are babbling about???
Old Nov 20, 2009 | 05:53 PM
It's a spammer Pete. They put in some incoherent text, with a link at the bottom to some website that we don't even want to go to.
Old May 13, 2010 | 09:55 AM
Carolinarednek's Avatar
Die spammer Die!!!
timopajala
67-69 V8 Tech
May 26, 2014 10:37 AM
kyphur
Jul 19, 2012 11:21 PM
hotrods1
67-69 I6 Tech
Jan 9, 2011 06:03 PM
johnson3034
May 25, 2007 09:35 PM
tb04512
Aug 19, 2006 12:37 AM
