oilpan....
ok so i bought a 94 camaro 3.4 V6 yesterday and when i took it to the mechanic b4 i ought they said it needs a new oilpan seal and a rear seal by the differential, any one know how much it really costs to do it they said about 300...
Buy the seals at autozone or whatever and then drain the oil from your engine. There isnt a way to drain your diff oil so just start unbolting it and it'll drain out. Scrape off the old seals and replace with the new. Refill engine oil, and on top the diff theres a place for you to add diff oil. http://www.bfranker.badz28.com/fbody/lubeoil.htm ....this should work good
