350 oilpan giving me hard time
Old May 25, 2014 | 04:09 AM
timopajala's Avatar
Default 350 oilpan giving me hard time
i canīt get the oilpan leak to stop...have changed new gasket etc and still dropping from the front...it seams like the front rubber gasket is too thin to make contact. I didnīt use any rtv during install, should i use rtv both sides of the gaskets?
the sides donīt leak...only the front seams to leak and little drop from the back...damn iīm frustrated at the moment...every time have to lift the engine to get the pan out etc so really hard job to do.
the pan is some kind of chinese peace i think because its chromed...is there supposed to be grooves in the oilpan gasket area? My old pan was flat and never had oil leak problems with that one, this has pressed grooves???
Old May 25, 2014 | 06:29 AM
Everett#2390's Avatar
Chrome items leak. Remove the chrome about the gasket surface, or Scotch-brite the bejesus on it.
Yes, there is a difference between a thick-gasket pan and thin-gasket pan.
Old May 26, 2014 | 09:41 AM
timopajala's Avatar
thank you very much! iīll remove the chrome from the gasket surface and buy new gaskets and reinstall everything...iīll report back after that.
Old May 26, 2014 | 10:37 AM
Smee78's Avatar
Good luck, I know these things can be a real pain.
1974z28
Jan 30, 2011 01:00 PM
80ZJoe
Aug 21, 2010 03:41 PM
tripwire1124
Aug 7, 2010 06:09 PM
DarlingReject
Jan 23, 2010 11:27 AM
tb04512
Aug 19, 2006 12:37 AM
