Annoying metal rubbing noise
Old 04-17-2015, 07:02 PM
whos_jonny's Avatar
Default Annoying metal rubbing noise
Please help me out- I have no idea what is causing this sound. When I start the car the sound seems the worst. It is like a metal scraping/rubbing against metal sound and it is present in neutral while the car is still as well as all the time I think in any gear or speed. The sound seems to be coming from the area of the tranny, but I can't be sure- besides, nothing is moving around while I'm in neutral, right?
This has been going on for a few weeks and seems to be getting worse but I don't think it is affecting performance (yet).
2000 V6 man trans
thanks for any insight
Old 04-18-2015, 08:21 AM
Being a manual trans, my first suspect would be the throwout/release bearing. Does the sound change at all when you push down the clutch pedal?
Something we can't do from here is get under your car to lend an ear, you're going to have to do that one.
Old 04-18-2015, 09:44 AM
being it makes noise worse when starter is engaged, also check starter to make sure its not hitting/rubbing the flywheel.
Old 04-18-2015, 11:35 PM
whos_jonny's Avatar
I checked and no, sound is unaffected by clutch depress. I'm thinking it must be a lower engine component/bearing but not sure where to start- ....it does still sound like it is coming from the area of the tranny. It is an intermittent sound. kkkk....kkkk.....kk.....kkkkkkk...
xxSithRagexx
82-92 V6 Tech
02-28-2015 12:57 PM
nathanh
06-04-2013 02:12 PM
cjoelmitchell
10-06-2009 12:19 PM
ChrisKJXN
LS Series Tech
09-17-2009 05:54 PM
Quick Reply: Annoying metal rubbing noise
