LS Series Tech 1998-2002
Rattling metal noise, something to do with a/c?
Old Sep 14, 2009 | 12:16 PM
ChrisKJXN's Avatar
Default Rattling metal noise, something to do with a/c?
Whenever my air conditioner is off, I get a noise from under the hood that sounds like chains or something metal rattling. Sometimes it gets really loud, and starting just about a week ago, whenever I turn on my defroster, the car stalls and won't start back up until I turn the a/c and defroster off. When it does start back up, it makes a very loud rattling and clunking noise and I have to stay on the gas or else it will stall again. Any idea what this could be? I've checked under the hood and see no loose belts or anything that looks out of place. Any help would be greatly appreciated.
Old Sep 14, 2009 | 06:23 PM
machine1999z28's Avatar
your A/C compressor is about to lock up. Try not to use heat or A/C till you can have it checked out. Same thing happen to a friends truck and it left him stranded when it finaly locked up. Sorry for the bad news
Old Sep 15, 2009 | 06:58 AM
maudyZ28's Avatar
mine does the same rattle but i just leave the a/c off, the heater works though. My car doesnt stall though its just the front plate of the a/c compressor that rattles on the pulley
Mine has a aux belt to run a/c only so it your is same you may be able to remove it but not sure if heat would work correct. As it stalls car it is prob on its way out. if you use a/c a lot look at getting a neew compressor
Old Sep 16, 2009 | 10:11 PM
ChrisKJXN's Avatar
Yep, just took it to a shop and they confirmed that the compressor won't even spin. Since I don't use a/c too much, I'm just taking off the belt. I hear on the LS1s that I can take that off without having to buy anything new. I'll take a look tomorrow morning to see what I can find.
Old Sep 17, 2009 | 04:08 AM
You can take off the belt and everything will be o.k. except your defrost wont work as well. The a/c compressor helps remove moisture from the heat/defrost system.
Old Sep 17, 2009 | 05:35 AM
maudyZ28's Avatar
yer it should be fine really. Mine has no gas in anyway so it turns off if it triess to come on, couldnt tell you about the moisture thing, it rains too much in the UK!
Old Sep 17, 2009 | 05:54 PM
ChrisKJXN's Avatar
Just took off the belt today and all is good, thanks for the help everyone!
xinterix
Sep 27, 2014 04:16 PM
C4r1b0u
Jul 5, 2010 02:01 PM
halo3
Feb 5, 2010 06:00 PM
pos97fbird
Apr 23, 2009 02:30 PM
rawktiludrop
Feb 13, 2009 10:34 PM
