Turning and getting grinding or rubbing noise
Old Jun 4, 2013 | 10:52 AM
nathanh's Avatar
Default Turning and getting grinding or rubbing noise
So for about 2 years now, when I turn left or right and back up left or right I hear a rubbing or grinding noise. all tires and rims are stock. Could this be a track arm problem?
Old Jun 4, 2013 | 11:12 AM
have you checked the fluid level in the rearend? was rear gear oil changed two years ago with maybe someone forgetting to add gm additive?
Old Jun 4, 2013 | 11:16 AM
nathanh's Avatar
Honestly I have no clue, even more stupid I have never checked it in over 2 years, and to top that, I don't even know how to check it....
Old Jun 4, 2013 | 11:20 AM
lol, maybe we can get arrow to take some pictures while he is dealing with his rear. lets see what i can find to help.
Old Jun 4, 2013 | 11:21 AM
nathanh's Avatar
I'm pretty sure my buddy knows how but the last month I've been at his house 28 out of 30 days either doing maintenance or upgrades, so I know he's about tired of me right now HAHA
Old Jun 4, 2013 | 11:33 AM
theres a plug on the front passenger side of the rearends center section. pull the plug and put finger in there, if you can touch the oil you should be ok. level is supposed to be within 5/8 inch of bottom of plug hole.
https://camaroforums.com/forum/lt1-l...l-fluid-50106/
Old Jun 4, 2013 | 11:56 AM
nathanh's Avatar
is that looking from the front or the back of the rearend?
Old Jun 4, 2013 | 12:25 PM
umm the other passenger side. lol. front passenger side of the center section. lets seee ok, opposite side of where the torque bar mounts on the rearend inbetween the fin looking things. you will see a plug with a square hole in the center, you stick a 3/8s extension on a rachet and unscrew it. the end of the extension will fit in the hole.
Old Jun 4, 2013 | 12:28 PM
oh and i have sams 35/22 hollow sway bar set.
Old Jun 4, 2013 | 12:30 PM
nathanh's Avatar
Because I just bought my strut toward and my next two steps are sway bars and torque bars, I haven't really done anything to the motor since I live in the mountains I love to handle better then speed
