LT1/LT4 Tech 1993-1997
what's the difference
Old Sep 2, 2011 | 08:06 PM
greenmachine96's Avatar
Originally Posted by craby
only way to tell if you have a 4 bolt is to drop the pan. all block id numbers are the same for the 2 and 4 bolt.
Chevy did that a few times on older engines too didnt they?
Old Sep 2, 2011 | 08:30 PM
i think so, i looked up the numbers on a 68 350 i have and it showed 2 or 4 bolt main. it has 4 bolt.
Old Sep 3, 2011 | 09:01 AM
bd92rs's Avatar
so what years were the LT4's produced
another reason i'm asking is i'm looking at a 94 trans am with a 97 model motor from a Z28 in it so i wanted to know if the 97 would be a LT1 or LT4
Old Sep 3, 2011 | 09:39 AM
not many lt4 were used in a camaro. came in the 97 slp ss camaro.
Old Sep 3, 2011 | 11:08 PM
Grandpaswagon's Avatar
The base Camaro Z28 and Trans Am from '93-97 all used the LT1.
From '98-02 they all used the LS1.
Old Sep 3, 2011 | 11:37 PM
grabbem88's Avatar
We knew that but GM did like to mix things up with there blocks though
Old Sep 4, 2011 | 09:01 AM
GM has had a history of using the same casting number for both 2 bolt and 4 bolt main applications.
I have a book somewhere in the garage that lists every V-8 casting number with the years of use, whether 2 or 4 bolt, and general applications (car, truck, etc). It was published back in the late '80s, so it obviously is not up to date, but it has a ton of info on Gen I small and big blocks.
YoungDriver
Apr 14, 2009 11:05 AM
flyinghigh2k8
Feb 19, 2008 05:30 PM
86irocz
Apr 2, 2007 06:33 PM
Sassy76
May 17, 2005 03:51 PM
