LT1/LT4 Tech 1993-1997
what's the difference
Old Sep 2, 2011 | 09:18 AM
bd92rs's Avatar
Default what's the difference
dumb question but i am a newby to the lt engines as this is the first 4th gen i have ever messed with
so could somebody tell me the difference between an LT1 and an LT4
thanks
Old Sep 2, 2011 | 09:40 AM
heads, cam and intake.
Old Sep 2, 2011 | 09:45 AM
Grandpaswagon's Avatar
The LT4 also has a different computer program to take advantage of the upgraded internals.
So, if you were to replace your heads, cam and intake on your LT1 to those from an LT4, you wouldn't have the full effect without a new tune also.
Old Sep 2, 2011 | 10:33 AM
Psycho's Avatar
LT1 vs LT4
Just a bit more than heads cam and intake.
Old Sep 2, 2011 | 12:39 PM
BasicConcepts's Avatar
Technical User
Also the lt4 is a 4 bolt main vs a 2 bolt on the lt1
Old Sep 2, 2011 | 12:50 PM
i have a 4 bolt main lt1.
Old Sep 2, 2011 | 01:32 PM
Technical User
Wouldnt that be a lt4 block tho
Old Sep 2, 2011 | 03:52 PM
nope, lt1 came with the 4 bolt in the vette and some camaro's
Old Sep 2, 2011 | 06:14 PM
grabbem88's Avatar
See I was told that the first yr z28 93 model used left over vette motors from 92 then when reviews were stellar from the general public demand GM switched gears and started producing for the 94 yr lt1 with the 2 bolt alter
I'm sure that's an old wives tale but I can dream can't I lol!
Old Sep 2, 2011 | 06:30 PM
only way to tell if you have a 4 bolt is to drop the pan. all block id numbers are the same for the 2 and 4 bolt.
