LT1/LT4 Tech 1993-1997
valve springs
Old Feb 11, 2012 | 03:11 PM
marten's Avatar
Default valve springs
Has anyone ever changed these with out taking the heads off, if so what tools did you use and where did you get it from. thanks ahead of time for any response.
Old Feb 11, 2012 | 03:30 PM
BasicConcepts's Avatar
Technical User
you need an air line with the same fitting as a spark plug that way you can pump pressurized air into the cylinder to hold the valves up. youll also need a valve spring compressor and a good magnet
Old Feb 11, 2012 | 03:56 PM
marten's Avatar
ok i have a valve spring compressor and air line just need to get a fitting then. thanks i wasn't sure if that would work.
Old Feb 11, 2012 | 04:31 PM
Technical User
ya they make lines about 15 inches long or so with the typical air line male on one side and the sparkplug threads on the other (its part of a compression gauge ive got one its pretty nice)
Old Feb 11, 2012 | 05:24 PM
bc what tool name and number is that id like to have one. here is a kit for just the spring change, im sure you can get one at your local parts store Crane Cams 99474-1 Crane Cams Cylinder Head Pressurization Kit the spring compressor will need to be able to fit back there in that little space. make sure you have one thats going to work on 7 and 8 cylinders.
Old Feb 11, 2012 | 05:45 PM
Technical User
its just a compression gauge i got mine from autozone oem brand
Old Feb 11, 2012 | 10:39 PM
AutoZone has the stuff you need in their loan a tools program: Valve Spring Compressor and Measure | AutoZone.com
tbl76camaro
May 14, 2010 08:05 PM
sesopha
70-81 V8 Tech
May 5, 2009 04:24 PM
95camz28
Nov 21, 2007 12:31 PM
sp9o3
Aug 9, 2007 11:12 AM
joeZ28
Jul 19, 2007 12:18 PM
