Best valve springs
Old Apr 22, 2009 | 10:26 AM
sesopha's Avatar
Default Best valve springs
I'm running a 350 in my '81 Camaro, I have a Performer RPM intake and camshaft, and a set of headman headers. I can't afford a set of heads, so I am going to be using the stock heads. So my question is, what kind of valve springs should I put on, or will a set of camelback heads with stock spring be fine?
Old May 5, 2009 | 04:24 PM
bobarian91's Avatar
BackseatBob
the Edelbrock valve springs that they sell FOR the RPM camshaft should be the best since they are designed for it. But even if you use the stock camelhumps i would buy new springs. The stock ones will handle the lift if I'm not mistaken, but you can replace them for relatively little cash so it's worth it. check ebay.
marten
Feb 11, 2012 10:39 PM
tbl76camaro
May 14, 2010 08:05 PM
95camz28
Nov 21, 2007 12:31 PM
sp9o3
Aug 9, 2007 11:12 AM
joeZ28
Jul 19, 2007 12:18 PM
