LT1/LT4 Tech 1993-1997
power steering pump
Old May 21, 2010 | 03:54 PM
red star's Avatar
Default power steering pump
well my power steering is acting weird on my 96 z28. my belt was squeaking really bad. i thought it was just the belt going bad. i had not had a chance to get to an auto parts store all i could do it hit it with a little WD40 (not really a fix i know) and worry about it later. well this morning i saw that the belt was making a noise becasue the power steering pump wasnt moving at all and the belt was just draging on it. is it my pump going bad?
Old May 21, 2010 | 04:39 PM
95slvrZ28's Avatar
Well if the pump isn't moving that's not a good sign. You can remove the belt and see if you can spin the pump by hand (it should turn easily), if not you may have seized a bearing and need to replace the pump.
Old May 21, 2010 | 07:18 PM
red star's Avatar
well it does it randomly. my power steering works fine too. most of the time its around start up.
Old May 21, 2010 | 07:40 PM
If the pulley on the power steering pump isn't spinning, the pump is bad. I recently had an alternator that was locked up while it had belt tension on it. With the belt off, it turned so-so by hand, but still didn't feel the best. Quite possible the belt tension is enough to make your bad bearing bind.
Old May 21, 2010 | 09:03 PM
red star's Avatar
do you think i can repair the pump? or would it just be best to buy a new one. is there any way i could find a blueprint for it"?
Old May 21, 2010 | 09:26 PM
shows in my book u can rebuid em. pick up a factory service manual for your yr.
Old May 21, 2010 | 09:35 PM
oh and would be easier and maybe cheeper to get a rebuilt one from the local parts store.
Bor3d
Apr 19, 2012 01:46 AM
Jonny Dubyah
Aug 4, 2009 11:07 PM
andkrs7
Apr 6, 2008 01:45 PM
qaz123
Apr 23, 2007 10:56 PM
mattyo010
Oct 19, 2006 01:01 AM
