LT1/LT4 Tech 1993-1997
noise in steering
Old Sep 16, 2006 | 03:10 PM
deang423's Avatar
Default noise in steering
My 96 Z has a creek or rubbing noise when turning hard left and right while rolling. Does it just need grease or is it a sign of bigger problems?
Thanks
Old Sep 17, 2006 | 02:13 AM
Default RE: noise in steering
When is the last time the ball joints got greased?
Old Sep 17, 2006 | 07:03 PM
deang423's Avatar
I've had the car a few months. I would imagine they need to be greased. What other issues would you look for with rack/pinion steering?
Old Sep 18, 2006 | 10:00 PM
The rack and pinion, outside of breaking or leaking fluid is not known for makin noises. You should look at the rest of the front suspension, such as tie rod ends, ball joints, bad wheel bearings, they complain going around corners, suspension and sway bar bushings dry out and make noise. But, a lot of people don't realize that the Camaro ball joints need to be lubed at every oil change and let them go to hell.
301Breed
Aug 13, 2012 12:44 PM
cmbtsupo
Aug 16, 2009 10:22 PM
hagaf22
Jul 17, 2007 03:51 PM
paulyfa
LS Series Tech
Jan 31, 2007 10:13 PM
Torque Junky
May 31, 2006 05:57 PM
