LT1/LT4 Tech 1993-1997
Need help with MAF sensor and tranny.
Old 08-21-2010 | 01:59 PM
RedSnakeZ28's Avatar
I cant find anywhere the control valve body
Old 08-21-2010 | 06:32 PM
patc has a kit to fix your problem, i would call and talk to them and see what they would recomend. found a rebuild on ebabe for like 100 bucks life warrenty whatever thats worth.
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_1342wt_834
Old 08-22-2010 | 06:38 PM
Thanks a bunch I will give them a call tomorrow. Now another thing i found weird, when I drive and I try to let the car coast, it fails to do so, it almost feels like im stalling the engine, or that the break pads are rubbing, but there is no squeaking, what can cause this?
Old 08-22-2010 | 07:38 PM
the torque converter will lock up on a slow down and if you touch the brakes it should unlock. the maf can be bored or if you plan on a good sized build you will want a little bigger one. i havnt done the research on the map for performance so im not sure were you need to start enlarging it. im thinking it was around 400 hp.
Old 08-22-2010 | 09:41 PM
So how do i fix that? And will it help to get a bigger one now??
Old 08-23-2010 | 12:54 AM
thats the way the converters work,,, if thats what it is. try touching the brakes just a little and let off. you should feel the converter disengage. could be a brake dragging.
no a bigger maf right now is not gona help.
Old 08-23-2010 | 10:13 PM
Tried tapping it and its a no go, it only drags when i am in drive when i switch to neutral it coasts.
Old 08-23-2010 | 11:19 PM
what rpms are we talking and at what speed? are you sure its going into overdrive? shift up through the gears manually and see if its shifting four times.
Old 08-23-2010 | 11:33 PM
if the maf is bad you should get the new maf in before doing anything else. it may be messing with the converter with bad info or the system is staying in limp mode. the valve body may have something to do with whats going on as well
fuhhuayt
05-05-2011 02:04 PM
EagleRex
07-20-2010 04:36 PM
bhoeksema
03-06-2010 09:38 PM
mpd228
05-11-2009 10:52 PM
sl1foru
11-12-2007 10:10 AM
Quick Reply: Need help with MAF sensor and tranny.
