LT1/LT4 Tech 1993-1997
map sensor
Old Nov 11, 2007 | 02:39 PM
sl1foru's Avatar
Default map sensor
ok my question is my 93 z28 camaro has some idling problems which stated in a previous post. now i was looking at my engine and realize this car do not have a map sensor, and mass air flow sensor on it. could this be the reason why this car shakes and runs rough. i just want to make sure. i used to own a 95 z28 and was wandering where are these sensors.
Old Nov 11, 2007 | 06:20 PM
Default RE: map sensor
Your 93 car should have a MAP sensor and no MAF sensor. It will not run without a MAP sensor. Check the ECM for trouble codes. If there are no codes put in a new set of plugs & wires & see if the idle improves.
Old Nov 12, 2007 | 09:10 AM
sl1foru's Avatar
ok thanks. i was goimg to tune it up this friday. spark plugs, wires , fuel filter, air filter, and change the pcv valve.
fuhhuayt
May 5, 2011 01:04 PM
imcdowel
Jul 26, 2010 11:59 AM
EagleRex
Jul 20, 2010 03:36 PM
Dznuts
Sep 27, 2009 06:48 PM
98sleeper
Nov 1, 2007 01:37 PM
