LT1/LT4 Tech 1993-1997
o2 sensor?
Old Jul 24, 2010 | 03:48 AM
imcdowel's Avatar
Default o2 sensor?
ok so my cars been throwing a check engine light when in the on position but not running. it was for an o2 sensor, i replaced the driver side and nothing happened. so i just replaced the passenger side before cat and it was still there, i drove around a little while and it seemed the same. then it started to hesitate really really really bad and the check engine light came on. wth is wrong? ill post codes in the afternoon. it ran fine a short while afterwords through my little back roads. also if this could be it, i only tightened it by hand since crows feet are a pita. ill tighten it this afternoon as well. any ideas?
Old Jul 24, 2010 | 04:21 AM
1BADA$$RS's Avatar
oh man oh man oh man dude i was working on a lincon navigator i changed all kinds of things out and it wound up being some kind of fuel sensor, i finialy took it to the ford house lol but it was a fuel sensor and some other bs im not a camaro or chevy expert but did you reset the ecm by taking the battery cable off
Old Jul 24, 2010 | 04:22 AM
1BADA$$RS's Avatar
it had the same symtoms as ur maro
Old Jul 24, 2010 | 09:13 AM
the 02 sensor needs to have a good ground. tighten the 02 and see what happens. also what kind of 02 did you use? stock oem sensor is the best. some of the aftermarket sensors dont last for some reason. i bought two cheap ones from the local parts store and they lasted for a couple days. took me the better part of a week to figure out the 02 were failing. fouled out my new plugs. unhooking the battery will clear the codes so read them before unhooking.
list the codes and we ll go from there.
Old Jul 24, 2010 | 05:38 PM
imcdowel's Avatar
Code is 'random misfire detected'. I'm going to go tighten it now.
Old Jul 24, 2010 | 05:45 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
just delete them, put sims in and call it good =]
Old Jul 24, 2010 | 06:08 PM
misfire could be plug wire or plug, check em out and see how they look.
Old Jul 24, 2010 | 08:10 PM
imcdowel's Avatar
funny, but cant put sims in place of before cats. or i would, i felt it and it wiggles a bit so that's more than likely the problem. i cant work on her since it just started with the bad weather but after a drive it runs great. i checked the plugs just in case and they appear to be fine though not replaced in who knows how long. ill reset the pcm and tighten it tomorrow but that's probably it.
Old Jul 24, 2010 | 08:51 PM
keep an eye on it. they will vibrate out if the wire will let it turn. one of the old ones i have plugging the back holes did. i didnt tighten them, forgot.
Old Jul 26, 2010 | 09:03 AM
DarkKnight's Avatar
GTO Killer
LimeKnight
delete cats too haha
