LT1/LT4 Tech 1993-1997
N.O.S. Safe?
Old Jan 6, 2007 | 09:45 PM
aap94z's Avatar
Default N.O.S. Safe?
Just lookin for some experienced nos users to tell me what hp jets i can use safely on a almost stock motor running premo. fuel and colder plugs. any advice would help thanks guys.
Old Jan 7, 2007 | 01:45 PM
Default RE: N.O.S. Safe?
If you inhale nitorogen oxyde in moderation it will make you silly and laugh a lot, but if you take in too much it will damage your lungs, the same thing happens to your engine.
Old Jan 7, 2007 | 02:33 PM
shnormo's Avatar
75 shot of nos will be safe for your car with premium fuel. I wouldn't go with colder plugs because when you're not using NOS it'll screw with the efficiecny of the combustion. The timing will be retarted by the computer because it's still within the built in tolerances. It'll be retarted only 1 degree with every 50 hp.
Old Jan 8, 2007 | 01:36 AM
aap94z's Avatar
ok so what should I do to my motor to allow it to handle a 150 shot?
Old Jan 8, 2007 | 12:39 PM
shnormo's Avatar
For that little shot of nos, it'll have to be a wet shot pretty much. I'd go with synthetic oil because that will cause more blow by due to higher pressure in the cylinder that results in diluting the oil. With a 150 shot you really get some where around the 70 hp mark to the rear wheels. At that point, your ring gap on your pistons should be shaved down a little bit more to allow for extra expansion with the extra heat burning fuel and N2O produces.
Old Jan 9, 2007 | 04:11 PM
carguylt1's Avatar
If your looking for street performance NOS is not a good idea. If the cops check your car and find it ready to use it is illegal.
Old Jan 9, 2007 | 06:15 PM
shnormo's Avatar
Ah the cops. It really has to be a purpose built car to have nitrous. That or drive around with the tank closed and the lines disconnected. But he did bring up a very very very valid point.
Old Jan 11, 2007 | 11:27 PM
aap94z's Avatar
so would it be safe for me to run a 150 shot at the track? with syn. oil.
Tyler31093
Apr 19, 2010 07:48 AM
maudyZ28
LS Series Tech
Apr 14, 2009 10:20 AM
Amy Z28
82-92 V8 Tech
Feb 5, 2009 01:31 AM
Spartan66
Feb 25, 2008 01:02 PM
00camaro00
Aug 21, 2007 06:55 PM
