my 94 z28 want start now
i have a 94 z28 and it was running fine ,i had to replace a manifold gasket and 2 bolts broke off in the head so i took it off and drilled them out and put evrything back together now it want start it turns over but want crank do u have any clue what causing this it ran perfect until i took apart ,everything is hooked up back like it was ?
You have an Optispark distributor, make sure all connections to & from computer, distributor, ignition module, and coil are in place & in good condition. Also scan the car for codes, they ma give a hint. If everything looks OK, you will need to do some basic trouble shooting, & go trough the whole ignition system one component at a time. Get a maintenance manual.
