Leaking Oil
Well, I got around to replacing the seal and it was leaking from it, but I have a new problem. When I went to start the car, it cranked for a little bit and finally fired but it was running rough and it would die shortly after or it would start and if I gave it any gas it would die. I traced all of the spark plug wires and they are in the correct spots and I checked to make sure that everything was plugged in. Could it possibly be the optispark? I know that I should have replaced it but money is a little tight so I decided to take a chance with it.
