LT1/LT4 Tech 1993-1997
Leaking Oil
Old May 28, 2010 | 09:29 PM
Bobby95z28's Avatar
Well, I got around to replacing the seal and it was leaking from it, but I have a new problem. When I went to start the car, it cranked for a little bit and finally fired but it was running rough and it would die shortly after or it would start and if I gave it any gas it would die. I traced all of the spark plug wires and they are in the correct spots and I checked to make sure that everything was plugged in. Could it possibly be the optispark? I know that I should have replaced it but money is a little tight so I decided to take a chance with it.
Old May 28, 2010 | 09:33 PM
sounds more like a fuel pump or filter problem. but yes it could be the opti.
Old May 28, 2010 | 10:02 PM
Bobby95z28's Avatar
I went out and tried starting it again and all it did was crank so I'll check the fuel pressure tomorrow morning.
Old May 28, 2010 | 10:26 PM
check for spark at the plugs as well.
Old May 29, 2010 | 09:57 AM
Bobby95z28's Avatar
Well, it turns out 1/4 tank is empty on that car lol . That's a lot different than my 95 v6 where I can go past E lol.
husker_camaro95
Nov 22, 2010 03:25 PM
My SilverJet
Jul 22, 2008 07:58 PM
bcharlton
Apr 14, 2008 05:05 PM
trishiepoo
Nov 3, 2007 06:54 PM
Mace587
Sep 18, 2006 12:20 AM
