LT1/LT4 Tech 1993-1997
Leaking Oil
Old Apr 26, 2010 | 01:36 PM
Bobby95z28's Avatar
Default Leaking Oil
Today I parked my 95 z28 outside and about 2 hours later I went outside and noticed that there was a lot of oil on the driveway. This had to have started today because I had it parked inside for the past few days with cardboard underneath and it wasn't leaking. I took a look underneath and it might be leaking from just below the optispark or from the timing cover but I'm not sure. I'll post pics shortly.
Old Apr 26, 2010 | 01:45 PM
Bobby95z28's Avatar
Sorry I'm not the best at taking pictures but I'll try to get better ones.
Old Apr 26, 2010 | 04:30 PM
Bobby95z28's Avatar
Well it seems to not be leaking right now but I'll let it sit for awhile and check it out later. I'm definitely going to look into fixing it. Any suggestions on what it could be?
Old Apr 26, 2010 | 05:50 PM
could be the intake or the water pump seal. i would look at the intake first. lt1 is known for the end seals failing. can u follow the trail?
Old Apr 26, 2010 | 07:22 PM
Bobby95z28's Avatar
I think it might be the water pump seal. I tried to trace it and it looks like it might be coming from it. It makes sense because I replaced the water pump a few weeks ago and that might have damaged it somehow.
Old Apr 26, 2010 | 08:07 PM
the pump shaft on the new pump probly is not in the exact same place as the old one so the stiff old seal was most likely used to the old one and not the new one. u should have replaced that seal. im sure 69 will be on to let u know that. well maybe not now. lol. theres a sticky on how to install correctly at the top of the lt1 or 4th gen section.
Old Apr 26, 2010 | 09:10 PM
Shoulda replaced the seal....Craby made me say it! But yeah, after going that far, it would have been a good idea to do it.
Try to wipe everything down as well as you can to remove the old oil crud, then see where the new oil trail comes from.
Old Apr 26, 2010 | 09:56 PM
Bobby95z28's Avatar
I'm really,really regretting it now but I didn't think about it at the time Taking everything apart the first time wasn't fun but it shouldn't take quite as long this time thanks for the help
Old Apr 26, 2010 | 10:28 PM
now dont get to far ahead of yourself. do like he said and wipe things down first and see if u can confirm thats were the leak is befor u take it all apart and fix the wrong thing. i had a slow leak in the power steering seal and it looked like a water pump seal leak. it was running down the mount and coming down from behind the opti. i would not have known it if i had not had to take the steering pump out when i changed the motor. there was a trail right up the mount to the front of the ps pump.
Old Apr 28, 2010 | 06:02 AM
torque_is_good's Avatar
another voice here to join the choir.
You had no oil leak
you replaced the waterpump
you now have an oil leak???
It appears to be more fluid than just occasional seepage
so, common sense says that something was disrupted but then again, common sense does not always prevail with automobiles.
Anyway, yes, you need to verify however, if it is leaking quite a bit, and it is the waterpump drive seal, then chances are that you now have a wee bit of wobble in the waterpump drive and don't want to drive with that too long unless of course you want to buy another waterpump.
Now, when you buy the timing cover gasket kit, it will come with 3 seals. Here is where only you can answer the question; are you going to replace all 3 seals since you are "in there" and play it safe (but take more time) or are you going after just the one? I know what I would do.....and have done.
for some reason I can't post the link to Autozone but here's the part # TCS45956 and it cost $10.50
