LT1/LT4 Tech 1993-1997
i need a block
Old Mar 13, 2009 | 04:23 PM
rondavis's Avatar
Default i need a block
i cracked my block and i need a new one and what is the stock cc s of a lt1 head just curious and can i use them if I build a mild 383 or not
Old Mar 13, 2009 | 04:29 PM
z28rob18's Avatar
well ill be sellin my old motor within a month. but id lik to sell it as a long block. as for the heads i believe there 52cc. and itd be better to do a 355 with more head work then do a 383 with no head work
Old Mar 13, 2009 | 05:01 PM
95slvrZ28's Avatar
Stock LT1 combustion chambers are 54cc. That said, without any additional porting on the heads and larger valves you're not going to be able to flow enough to accommodate a 383.
Edit: I just realized you didn't specify the 'cc' of what you wanted, so here, have more info:
Combustion Chamber: 54cc
Intake Port: 170cc
Intake Valve: 1.94"
Exhaust Valve: 1.50"
Flow: 212 cfm
Old Mar 13, 2009 | 09:46 PM
rondavis's Avatar
that is ok i figured that i would need work done to the heads but i do really need a block but thanks any ways
Old Mar 13, 2009 | 09:48 PM
Saint_Ali's Avatar
how bad is the crack ? you can take it to a machine shop to be welded or have plugs put in
Old Mar 14, 2009 | 09:27 AM
rondavis's Avatar
it is in the crank journal
decaen
Feb 16, 2012 01:08 AM
tecumseh
Mar 8, 2011 01:01 PM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
Carinhas
67-69 V8 Tech
13
Aug 23, 2007 05:02 PM
