LT1/LT4 Tech 1993-1997
heater hose replacement HELP!
Old Aug 31, 2009 | 08:47 AM
94LT1Z28's Avatar
Default heater hose replacement HELP!
i have a 94 z28 and i am replacing the heater hose (runs from the water pump to the fire wall) i am trying to figure out how to remove it without cutting it in pieces, and then i have to put a new one in. so if anybody could help me that would be great.thanks
Old Aug 31, 2009 | 09:25 AM
never changed one dont want to. book says,, drain coolant. unhook clamps at both ends and twist and turn it to get out. looks to me like u may have to remove alt to make it easier. tight fit huh.
Old Aug 31, 2009 | 11:34 AM
94LT1Z28's Avatar
already taken the alternator out and i may have to take out the bracket too...the a/c seems to be in the way. i was also wondering if i will have to drop the motor just to replace that hose.
Old Aug 31, 2009 | 11:44 AM
no i think once u get all the mounting brackets and clamps undone it should come out. which hose went? both? which end?
Old Aug 31, 2009 | 07:25 PM
94LT1Z28's Avatar
the hose that was busted was the one that connects directly to the water pump, and where the hole was it was spraying onto by belt which made it slip and quite literally ripped my belt right down the middle, so i basically had 2 belts lol. but i think we got it under control now and hopefully by tomorrow morning ill be able to drive it again. I can't wait because until it gets fixed i have to drive my friends ford taurus lol and its terrible.
Old Aug 31, 2009 | 09:48 PM
cool...
Tonylig928
Dec 30, 2009 07:38 PM
Gorn
Nov 8, 2009 09:34 AM
camrov6
May 22, 2009 01:11 PM
vabeachxj
82-92 V8 Tech
Nov 28, 2008 03:38 PM
Rihavens
Feb 4, 2008 08:45 AM
