LT1/LT4 Tech 1993-1997
Clutch...
Old Apr 14, 2010 | 02:29 AM
Dillon5224's Avatar
Default Clutch...
I have one, now how much should I expect to pay to get it installed??
Old Apr 15, 2010 | 12:31 PM
ill do it for a couple hundred. lol,,, u would need to come here though and help. well it depends on if the flywheel needs turning or replaced, if not a shop will probly be in the 4 hundred range and dealer a little more. remember its been a while sence ive had a car in the shop so numbers could be off. give your local dealer a call and ask what the booktime cost is for changing clutch. that will give u a baseline cost for just changing parts.
Old Apr 21, 2010 | 01:34 AM
Dillon5224's Avatar
Update:
I called the local shop and they said they'd do it for $400. My dad (40 years + experience) said I'd have to turn the flywheel.. what exactly does that mean, and that means the $400 won't prolly cover the turning?
Old Apr 21, 2010 | 10:23 AM
the flywheel and pressure plate is where the heat is mostly disipated from the clutch disk. they will get cracks in them and get heat scorching. both can cause problems if left in an unaceptable condition. so if the flywheel is not in to bad of condition it can be turned or machined to remove a layer of steel from it to get below the damage. if it just needs turned then cost should not be effected much, if it needs to be replaced then u will see a jump.
Old Apr 21, 2010 | 10:53 AM
Dillon5224's Avatar
I hope i didn't mess up my flywheel, what are signs of that?
Btw, car only has 50,000 miles
Old Apr 21, 2010 | 12:39 PM
ya gotta take it apart and see. couple are if cracks are to deep and if heat has warped it. if its just starting to go and has not been revved up to much while slipping u should be ok.
Old Apr 21, 2010 | 10:01 PM
383Stro's Avatar
Costs 30-40 to resurface the flywheel, yours will be fine Im sure, They only take off a minimum amount each time. I have turned a stock one three times and they sell a shim to put between it and the crankshaft so dont worry you will be just fine.
dogdog130
Jun 28, 2012 04:28 PM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Rise65
Nov 8, 2007 10:58 PM
Pro_built7
Apr 10, 2007 02:07 AM
