LT1/LT4 Tech 1993-1997
camshaft and ST header instal labor and tips
Old 01-22-2012, 05:16 PM
BasicConcepts's Avatar
Technical User
Originally Posted by numskull223
To change springs, and seals....its just easier.
thats not true if you can get pressurized air into the cylinder (there is a hose you can get at the parts store to attach to a compressor) that will hold the valves shut in turn no need to pull the heads
Old 01-22-2012, 05:31 PM
bob97z28's Avatar
ive read this too. Is anyone in VA on here that knows how? i dont know anyone who would wanna help (that has some automotive knowledge.)
numskull223's Avatar
Yes, you can. But the tight space it is easier. If you have to machine for the springs or studs they gotta come off.
Old 01-22-2012, 05:36 PM
Technical User
very true
Old 01-23-2012, 05:42 PM
DrmMaster's Avatar
Smile
Originally Posted by bob97z28
1.looking at picking up a GM847 cam with 610' Lift Springs and valve seals. 3/8 rocker studs And guideplates. and hardend pushrods,, 200bucks,, is that a good deal ?
2. also what will the labor on that run me with also doing shorttube headers and y pipe?
3. What else would be recommended to do during this time and costs?
Thankyou
Bob,
from (the craigslist guy) "me". Just buy my parts already!
Tim
Old 01-23-2012, 05:43 PM
bob97z28's Avatar
hahahahahah, I need my check with my resources first.
Old 01-24-2012, 02:26 AM
with that kind of lift and rpm range your looking at building the bottom end. also going to need other mods like rear end and trans improvements. good cam just not so streetable. do you need to pass emissions tests? bc considering the ease of changing spark plugs attaching the air hose to the heads would be a breeze right...
Old 01-24-2012, 03:48 AM
check my build thread,,, this is what it sounds like,,, im not a very good photo guy
led plate lights and nice idle sound track - YouTube
lt1 with raptor level 3 4l60 - YouTube
Old 01-24-2012, 12:45 PM
Technical User
the only plug i had trouble with was cylinder 8 and i got some big arms
  #20
Old 01-24-2012, 12:52 PM
yep its one thing to squeeze your arm in there to get the plug to start, another to get a hose in there. im sure it can be done. other side of it is getting the spring to compress and get the retainers in on the back cylinders. i almost went that route but getting a spring compressor that would fit in there was a challange.
Patrick Quentin Musick
03-19-2013 09:38 AM
bob97z28
07-01-2012 05:08 PM
TylerTman
04-19-2012 11:09 AM
mshaeffer
06-02-2008 06:55 PM
Quick Reply: camshaft and ST header instal labor and tips
