LS Series Tech 1998-2002
Long tube header install on jack stands, 02' z28. Need advice tips or tricks
Old Jul 20, 2010 | 04:47 PM
boostedzx3's Avatar
Default Long tube header install on jack stands, 02' z28. Need advice tips or tricks
So tomorow it appears i'll be helping my buddy w/ his headers on this z28. I just need tips tricks and advice of the easiest way to go about this. What all should we get out of the way first? I see the filter dryer and the A/C lines are in the way on the passenger side amongst other things. Then on the driver side the steering knuckle, and WTH w/ that rear bolt?
Old Jul 21, 2010 | 04:55 PM
libertyforall1776's Avatar
I would consider changing your motor mounts for some poly ones to prevent sagging and having your Y-Pipe bang the floorboard!
Old Jul 22, 2010 | 11:29 AM
boostedzx3's Avatar
Ah thats the first i've heard that one, thanks Im really hoping the Y pipe doesnt bang off the floorboard as is I guess we will see.
Old Jul 22, 2010 | 07:47 PM
boostedzx3's Avatar
Done, im guessing not a whole lot of people tempt this task themselves and take it to a shop? I'll admit its not as bad as it looked however the 2 center bolts on the passenger side can only be tightened with a 10mm closed end wrench on the long tubes b/c of the position of the air injection. The air injection system is a pain on the long tubes b/c its in a tough spot to get a wrench on and the drivers side we had to disconnect the steering linkage. The front o2's are definetly no where close to the factory spot so obviously the wires needed extended and that was about it.
Old Jul 22, 2010 | 09:16 PM
Talked about all over LS1tech...
jjc1800
Jun 24, 2011 02:47 AM
jbe123
70-81 V8 Tech
May 24, 2010 11:21 PM
SS/Z28cam
Feb 18, 2010 09:45 PM
RicoSuave97TA
Jan 1, 2007 05:39 AM
gotalcoholmanup
Apr 11, 2006 09:24 AM
