long tube header problems, (HELP)
Old May 12, 2010 | 04:08 PM
jjc1800's Avatar
Default long tube header problems, (HELP)
got a 69 camaro with a new 383 stroker installed. my uncle is having a problem putting on the headman headers on the drivers side. he cant get the header up tight against the head because the steering knuckle is in the way. we are thinking that we will have to heat up the section of the tub with a torch and then flatten it out a bit with a hammer so it will clear the steering knuckle. what do you guys think , is this the way to go?
thank guy , jeff
Old May 12, 2010 | 06:50 PM
As long as it doesn't need too much of a dent to clear. If it's not more than maybe 1/3 of the diameter it wont be a major issue. More than that and it will restrict proper flow. Try to make it gradual too. A tapered indent is better than a sharp small indent to keep gases flowing good.
Old May 12, 2010 | 10:54 PM
The steering knuckle? Do you mean the pitman arm off the bottom of the steering box is hitting the collector tube? The only thing that could get in the way up above would be the steering box itself. My car has manual steering which gives a little more clearance over a power box. I can just squeeze my finger between the tube and steering box, but there's nothing in the way underneath. However, I don't have Hedman headers. Do you have pictures?
Old May 13, 2010 | 06:33 AM
jjc1800's Avatar
well my uncle calls it a steering knuckle, but yes the steering box. the car has power steering.
Old May 13, 2010 | 08:56 AM
burnt68's Avatar
December 2010 ROTM
mark the spot on the tube that needs to be dented and then just use a socket long ways across the tube (horizontil to where the gear box hits) and tap it with a hammer it will make room and not restrict the flow in any way!!
Old May 19, 2010 | 02:11 AM
kamaro68's Avatar
I have the same issue with my 68' with power steering. I have the Hooker Super Competition Ceramic long tube headers and they got all scratched up from one of the bolts on the steering box rubbing against the header when the motor torque's at high revs. I need to "slightly modify" my headers also. There has to be a better way than banging on a pair of $689 headers?
Old May 19, 2010 | 07:22 PM
Nope, not really a better way that wont harm the surface of the headers. You could heat it with a torch and gently tap it in, but then the heat would discolor the coating.
Old May 19, 2010 | 09:06 PM
The best way to avoid banging up a pair of $689 headers, is by buying a pair of $289 headers!
Old May 24, 2010 | 11:01 PM
Squid's Avatar
for installing the headers with engine in....pull the steering box off, install headers, reinstall steering box.
Old Jun 24, 2011 | 02:47 AM
kamaro68's Avatar
I just noticed that apparently I have built up some equity in my headers. I just looked them up on Summit and they are now $695.95
boostedzx3
LS Series Tech
Jul 22, 2010 09:16 PM
SS/Z28cam
Feb 18, 2010 09:45 PM
jbe123
Sep 7, 2007 12:40 AM
RicoSuave97TA
Jan 1, 2007 05:39 AM
gotalcoholmanup
Apr 11, 2006 09:24 AM
