94 z28 no start
the system for the tach use's the readings from the opti to run it. if theres no message from the opti then its not working right or there s a bad connection between there and the coil. if the tach works it does not mean the opit is good just tryin to get a little more info that would point to it
Hmmm! I thought I posted the fix that I found. I some how managed to break the hot wire going to the coil. The insulation of the wire was the only thing holding the connector to the wire. I purchased a new connector and pigtail from NAPA and soldered it in, plugged it in and fired that car up. Hasn't missed a lick since.
