LS Series Tech 1998-2002
Differential and driveshaft question
Old Mar 1, 2007 | 11:14 PM
JaySan's Avatar
Default Differential and driveshaft question
I am curious but do 2000-2002 camaro SS/Z28 do they come stock with an aluminum drive shaft? and what gears do they have stock ? Posi, LSD ? 3.73? 4.10? because i was on ebay and I saw an aluminum driveshaft for and LS1 and 3.73 gears from a 70's camaro and I was wondering if these parts would work on a 2000 V6 camaro ?any info is greatly appriciated
Old Mar 2, 2007 | 10:35 AM
JD1969's Avatar
Default RE: Differential and driveshaft question
LS1's come with an aluminium drive shaft stock, I'm not sure about your V6. 6 speed cars had 3.42 rear gears,autos had either 2.73 or 3.23's. The gear from a 70's Camaro will not work with your car. A gear swap is a good idea, but the driveshaft is a waist of money, it will not do anything for performance.
Old Mar 2, 2007 | 03:35 PM
JaySan's Avatar
i was told by some one if you put and aluminum drive shaft it will give more RWHP or free up more. My drive shaft right now is stock made out of steeland its a 2 piece drive shaft. So it takes more power to spin a steel drive shaft then it would take to spin a lightweight aluminum drive shaft. and i want to use the aluminum driveshaft from an LS1
Old Mar 3, 2007 | 12:48 AM
JD1969's Avatar
It might free up 1 maybe 2 hp, but probably not. Your money is better spent on mods that will actually give you HP, but it's your money to waiste, besides what do I know
BoSoxFanSims
Aug 21, 2011 10:03 AM
z28anthony
Dec 12, 2010 07:51 PM
02CamaroV6
Jun 4, 2009 08:39 PM
SickSickSick
Jun 2, 2006 10:17 AM
SickSickSick
Jun 1, 2006 09:49 AM
