Intake leak
Old Nov 11, 2010 | 07:36 AM
forevverlost's Avatar
Default Intake leak
I have an intake leak that is causing some issues. My question is would it be ok for a month or so to use blue goo or some kind of gasket sealant as a temporary fix till i get the money for repair?
Old Nov 11, 2010 | 08:10 AM
if its leaking coolant i would say no, a quick fix is not a good idea. if its a vacuum leak then it may work but you would want to use high temp rvt and let it dry. it would be best to replace the gaskets and do it right.
Old Nov 11, 2010 | 08:55 AM
its not leaking coolant just a vac leak. and i agree but im just strapped here for the next month or 2. definately top of the priority list tho.
Old Nov 11, 2010 | 12:02 PM
Where is it leaking, and what are the issues?
Old Nov 11, 2010 | 01:21 PM
its leaking from the drivers side about middle way. i believe it is causing it to run lean and cause the piston to get hot and causing early detonation... pinging during acceleration
frumpy
Mar 6, 2014 12:56 PM
Kendagenius
Jul 18, 2010 10:02 AM
C Rod
Jan 7, 2010 08:53 PM
Vandee
Nov 19, 2009 07:04 PM
HURSTLT1
Jan 19, 2006 06:23 PM
