LT1/LT4 Tech 1993-1997
intake leak????
Old Jan 14, 2006 | 12:09 AM
HURSTLT1's Avatar
Default intake leak????
i've heard a few things about the intake manifold leak....is it a flutterinng sound almost like an exhaust leak?...i know my egr is bad and i am replacing it....
Old Jan 14, 2006 | 09:07 AM
bjames5's Avatar
Default RE: intake leak????
I have not heard anything as far as the sounds go but I have owned a 95 and now I have this 93 Camaro Z28s and both leaked oil from the intake. They both leaked in the rear portion of it.
Old Jan 15, 2006 | 11:54 PM
The common intake oil leak makes no noise, it just makes a mess. An air/vacuum leak in the itake may or may not make noise, but it will make the car run bad. If it is bad enough to make noise, it is usually a high pitched whistle.
Old Jan 19, 2006 | 06:23 PM
94Z28SHAKER's Avatar
The reason that most LT1's leak from the intake manifold is either a bad casting or the bendable little tube right behind the intake manifold(egr?) is too close to the gasket and needs to be pulled away, and heat wrapped. I youve ever fixed one you can see a yellow stain/burn mark on the seat right by where that tube would be, its not a problem if the mark is there it just confirms that it was the culprit. usually the rear left if looking at it from the front.
frumpy
Mar 6, 2014 12:56 PM
forevverlost
Nov 11, 2010 01:21 PM
Kendagenius
Jul 18, 2010 10:02 AM
C Rod
Jan 7, 2010 08:53 PM
Vandee
Nov 19, 2009 07:04 PM
