tranny ?
Old Jun 24, 2007 | 02:51 PM
onefastlt1's Avatar
Default tranny ?
could a 95 z28 auto b as faster or faster then a manual n how would i do that ? transmission wise not by the engine
Old Jun 24, 2007 | 03:08 PM
Default RE: tranny ?
If the engines make the same power & torque, and the drivers are of equal skill, the auto usually gets off the line quicker than the manual, but the manual has a higher trap speed. The ET is a toss up. The auto has a deeper first gear and torque multiplication by the torque converter and is able to get off the line quicker. The manual is more power efficient and catches up on the top end. The main advantages of the autoare consistency and less stress on the power train.
Old Jun 24, 2007 | 04:51 PM
onefastlt1's Avatar
what if i got 3.73 gears in the auto
Old Jun 24, 2007 | 05:49 PM
JaySan's Avatar
you could buy a shift kit .
http://rksport.com/main/part_detail....=1&catid=3
or RKSport.com is the home page
Old Jun 24, 2007 | 06:31 PM
onefastlt1's Avatar
what does a shift kit actually do?
Old Jun 24, 2007 | 11:51 PM
JaySan's Avatar
qicker and better shifts . it would be faster than a manual. plus a computer can shift faster than a human.
Old Jun 25, 2007 | 12:29 AM
t9ojetpilot's Avatar
[:@] by faster are meaning top speed, off the line, quickness of the shifts?? what is it your attempting to do, what result are you looking for?? kurt
Old Jun 25, 2007 | 04:59 PM
z28 john's Avatar
With today's technology, it's quite normal to see an automatic either equal or beat a manual-tranny (with a competent driver in both)!
The key to running automatics is to figure out the best combination of available-parts, for your application.
My SC'ed Z has a Corvette servo, & Eagle components in it's 4L60.I also have a 2400 B&M converter to help it build rpms off the line. Do some research, & you'll find what you need!
BTW, I ran side-by-side at 135 mph (& gaining) with a 3.42 gear, while racing a 6-speed '06 GTO- which had the double-overdrive! That's after I beat him by three cars from 0-100, then let him catch-up for the top-end run! So, IMHO, the stick doesn't necessarily win on the top-end, either!
Peace!
John
WIspartan1026
Mar 25, 2010 09:58 PM
bhoeksema
Mar 6, 2010 08:38 PM
blowncamaro
Oct 12, 2009 09:05 PM
rancheronut
Jul 14, 2009 01:12 AM
mpd228
May 11, 2009 09:52 PM
