Tensioner pulley removal
Old Mar 3, 2006 | 06:59 PM
ImmortalfWd's Avatar
Default Tensioner pulley removal
I have a 97 with a 3.8L. As I was driving home today my belt snapped, I was kinda shocked as it's fairly new. As I'm replacing the belt I notice that the pulley on the tensioner assembly needs to be replaced. How do you remove the pulley? Is it held by the same bolt you use to loosen the tension for removing/installing the belt?
Old Mar 5, 2006 | 08:05 PM
v8chvyguy's Avatar
Default RE: Tensioner pulley removal
I think the pulley unbolts from the tensioner arm, that's how most GM's are built. Some, the hole tensioner assembly gets replaced. Check and see what the parts house gives you.
Old Jan 4, 2007 | 10:20 AM
Foskey's Avatar
I have a simliar issue. Did you ever get the pulley replaced?
Old Jan 4, 2007 | 02:53 PM
Foskey's Avatar
The pulley removeal is seperate and a cake walk to replace.
Old Jan 7, 2007 | 12:05 AM
JGaeta03's Avatar
I replaced my whole tensioner assembly cause it was lose on the swivel.
ded2me
Mar 14, 2014 10:56 PM
crazyleroy
82-92 V8 Tech
Nov 9, 2011 12:24 PM
x01660
Jul 14, 2011 09:34 PM
usnfenix
LS Series Tech
Jan 24, 2010 09:32 PM
3.4CamaroCDOG
Jan 5, 2008 02:44 PM
