Aluminum Heater hose from tensioner pulley housing
Old Mar 14, 2014 | 10:56 PM
ded2me's Avatar
Default Aluminum Heater hose from tensioner pulley housing
While taking off my timing cover and tensioner pulley housing I found a weak spot in the design. Not sure if many know this or not so I am posting the info here.
There is a small plastic elbow that transfers the coolant from the tensioner pulley housing to the heater hoses. When I took mine off I noticed that the original plastic elbow had broken off inside the hole (Under the intake). THANK GOD for small hook tools. I fished it out.
I found these aluminum ones that would fix this problem indefinitely. Highly recommended. Glad this happened now or I would have never have known.
Comparison:
Showing how the plastic OEM elbow failed.:
vanquishfist
Mar 20, 2013 12:20 AM
crazyleroy
82-92 V8 Tech
Nov 9, 2011 12:24 PM
x01660
Jul 14, 2011 09:34 PM
3.4CamaroCDOG
Jan 5, 2008 02:44 PM
ImmortalfWd
Jan 7, 2007 12:05 AM
