sensor
Old Jul 28, 2008 | 04:15 PM
pem's Avatar
pem
Default sensor
can i get to the fuel sensor from under the carpet in my trunk? any and all advice welcome
Old Jul 28, 2008 | 08:48 PM
Default RE: sensor
If you are talking about getting to the fuel level sensor by just lifting the carpet it won't happen. You will need to cut a hole in the floorboard. Otherwise, the fuel tank will have to lowered.
Old Jul 29, 2008 | 09:43 AM
pem's Avatar
pem
Default RE: sensor
is it inside the tank, should i replace the whole tank, or is it cheaper to replace the sensor?
thanks
Old Jul 29, 2008 | 11:58 AM
02StanGT's Avatar
Default RE: sensor
Fuel level sensor isin the tank as a part of the fuel pump assembly.
Old Jul 29, 2008 | 12:50 PM
pem's Avatar
pem
Default RE: sensor
any ideas on the repair costs?
thanks
Old Jul 30, 2008 | 02:11 AM
02StanGT's Avatar
Default RE: sensor
http://forum.camarov6.com/showthread...el+pump+access
IfYOU can do what's in the thread, then cheap. Otherwise, you'll pay for the labor of droppingTHEM tank out the bottom.
Old Jul 30, 2008 | 11:09 AM
pem's Avatar
pem
Default RE: sensor
so i should just replace the whole thing?
Old Jul 30, 2008 | 12:10 PM
02StanGT's Avatar
Default RE: sensor
I'm not sure you could replace just the level sensor. Everywhere I've seen, they come as a pair.
Old Jul 30, 2008 | 12:47 PM
pem's Avatar
pem
Default RE: sensor
found a walbro hi flo fuel pump for $119. Question though, my car starts fine except it reads full for awhile, then fluctuates between empty and full, is this still a pump issue or could it be something else?MAYBE THE FUEL FILTER?
fuhhuayt
May 5, 2011 01:04 PM
imcdowel
Jul 26, 2010 11:59 AM
EagleRex
Jul 20, 2010 03:36 PM
Dznuts
Sep 27, 2009 06:48 PM
98sleeper
Nov 1, 2007 01:37 PM
