Check engine might be probelm with ecu what do you think?
Old Jul 27, 2008 | 04:34 PM
racerbo836's Avatar
Default Check engine might be probelm with ecu what do you think?
i had a check engine light come on in my 88 iroc z. i hooked up my scan tool and it told me that my car was not reponding.so i hooked it up to 3 other cars and it worked fine. could there be something wrong with my ECM or CCCS? or something as small as a blown fuse or something? any advise would help right now or it also has a 5.7 liter v8 would that make a differnce?
Old Jul 27, 2008 | 06:12 PM
Default RE: Check engine might be probelm with ecu what do you think?
Check your cigarette lighter/power outlet fuse. Don't know how far back it goes, but some of the more current cars power the OBD port on the same circuit. Had that happen to me on a 97 Cavalier.
Old Jul 27, 2008 | 06:41 PM
racerbo836's Avatar
thank you i will check it out i was thinking a fuse but i dont know much about OBD.
Old Jul 27, 2008 | 06:47 PM
racerbo836's Avatar
ok i checked the fuse and its fine. anything else i could check. been trying to figure it out for awhile
Old Jul 27, 2008 | 10:14 PM
MadMikeZ28's Avatar
I don't recall ever seeing a power wire on OBDI. Did you try the paper clip in theAand B on the ALDL?
Old Jul 28, 2008 | 03:01 PM
racerbo836's Avatar
the check engine light only comes on when the car is running but yes i checked it with paper clip and the check engine light does not blink.
Old Jul 31, 2008 | 09:21 PM
racerbo836's Avatar
you guys are a big help!
92camarors305
Jan 7, 2011 12:04 PM
gerod11
Jun 11, 2010 12:35 AM
Chevykicksbut
Oct 28, 2009 07:14 AM
Chevyfan99
Jan 13, 2008 12:57 AM
teamlilE1
Mar 12, 2006 02:22 AM
