Rearend Question
Old Dec 31, 2010 | 12:41 AM
mick.mcgirr's Avatar
Default Rearend Question
I am potentially buying a 10 bolt rearend with posi and 355's in it tomorrow. It is used and hasn't been in a vehicle in 10 years. What should I be checking on this before purchasing? It is out of a '69 with multi-leaf, like mine, so fit shouldn't be a problem.
Old Dec 31, 2010 | 01:38 AM
Pablo63's Avatar
Banned
From: Raised in Tilton NH now residing in Kings Mountain KY
Go to the 1st gen section and click on one of the stickies. There is a link to codes you can use to verify the rear is what the seller says it is. You should also remove the rear cover and inspect the ring and pinion for any badly worn or broken teeth. Check for metal in the fluid as well.
Old Dec 31, 2010 | 01:42 AM
Pablo63's Avatar
Banned
Here found it for you. I don't see any 10 bolts with 3.55's and a posi thou. Maybe I'm missing it thou. I'm overtired, LOL
http://www.camaros.org/drivetrain.shtml#AxleCodes
Old Dec 31, 2010 | 03:11 AM
Thanks a bunch. I'll check that. He had sent me the following code, but it doesn't seem to correspond to what he's telling me it is... 2 PY 680371. He says it was from the top right axle tube... hmm.
Old Dec 31, 2010 | 07:30 PM
Decoded it. It's a 78 Pontiac rearend, and based on the code from the ring gear inside, it wasn't a 3.55, it's a 3.42. If anyone wants it, it's just north of Seattle for $200. I'm not going to buy it.
Old Dec 31, 2010 | 07:58 PM
Pablo63's Avatar
Banned
Did it come back a posi? just curious if he had that right,lol
Old Jan 1, 2011 | 02:36 AM
Not sure, he says it is, but with as much as he was way off with everything else, I'd doubt it. hahaha
1quik4
Oct 31, 2010 08:49 AM
Tom071
Apr 15, 2010 06:53 AM
JeepGuy12
Jan 1, 2010 11:59 AM
77LT107
Feb 13, 2008 03:04 PM
2000Z28
LS Series Tech
Apr 7, 2006 02:10 AM
