I need help with a noise
Old May 29, 2010 | 05:43 PM
^ Hmmmmm, and with online payday links at the bottom too?
Naaaaa, I think he's just excited to tell about his computer and the spam links are a coincidunce, yeah that's it.
Old Jun 7, 2010 | 10:17 AM
Buckeye69's Avatar
Originally Posted by ocpmann
Hello, and thanks in advance for any help
I'm working on a 99 ls1 camaro. It came in with the carrier in the diif was broken. I replace the carrier the gears, the axles, and every bearing in the rear end. After it was back togeather I drove it, and it has a noise. Apperently the noise was there before the rear end broke. I thought it might be tire noise, so I put the tires on anouther camaro, and they made no noise. I even change the U-joints in the drive shaft. Any Ideas?
Did you figure it out? I was thinking to count the number of sounds its making each time you hear it, within a 10 second interval, noting the RPM you are at. The thought is what rotates based on its diameter that would match the info you've pulled together base on that sound. Just a thought.
First though why do you think the carrier failed?
B_Dubya
Mar 27, 2015 02:10 PM
DashingDaryl
Apr 4, 2012 02:46 PM
AKLDan2k1
Aug 23, 2011 07:56 AM
supreme_style21
Jun 8, 2010 06:36 PM
EddieTheRipper
Oct 11, 2007 08:57 PM
