Fans INOP!
Old Apr 28, 2008 | 08:46 PM
96z6spd's Avatar
Default Fans INOP!
My fans will not come on when theyre supposed to. At idle the car heats up fans wont come on. When you turn the ac on they will come on. Tested all 3 relays, new ect sensor on the water pump. Car drives fine with ac on but with it off at idle the car gets too hot almost to the red! Any suggestions?
Old Apr 29, 2008 | 12:19 AM
t9ojetpilot's Avatar
Default RE: Fans INOP!
[:@] aaahhhhh the extra hot camaro not to worry the general decided that the fans dont need to come on until around 220 deg. sadistic i know but this is normal. now if they dont come on at all or the needle is buried in the red then we have a problem kurt
Old May 6, 2008 | 07:58 PM
Goodfella's Avatar
mines got the same deal, but i noticed that where the coolant fan temp sensor used to be was just a single prong connector coming out of the block, and a single wire was hanging down in the same area. That gonna be my project for the weekend... good Luck
Old May 6, 2008 | 10:00 PM
Saint_Ali's Avatar
check the grounds leading on the left side of the engine bay by the battery, you have 2 sets of fans, a high and a low.
1999chevy
Jun 21, 2009 12:23 AM
camaro girl
Dec 9, 2008 06:47 PM
camaro girl
Oct 11, 2008 04:54 PM
thetal1
Sep 28, 2008 02:21 AM
TEXASMAN1
Apr 23, 2008 03:41 PM
