abs inop
Old Apr 17, 2008 | 11:48 PM
TEXASMAN1's Avatar
Default abs inop
my abs inop light comes on sometimes but they work fine. what do yall think it is?
Old Apr 18, 2008 | 12:07 AM
95slvrZ28's Avatar
Default RE: abs inop
Probably a wheel speed sensor that is either going bad or has a bad connection. I had that issue for about 6 months before it fixed itself...
Old Apr 18, 2008 | 05:29 AM
SpecterGT260's Avatar
Ninja Administrator
in my old mustang the ABS light came on alot when my brakes were dangerously low. I dont know if it works the same for camaros, someone else may be able to confirm this
Old Apr 18, 2008 | 11:42 AM
TEXASMAN1's Avatar
so where is the sensor at so i can see if i can fixit?
Old Apr 18, 2008 | 05:10 PM
02StanGT's Avatar
Seeing as they are wheel speed sensors, one would only guess they are near the wheels...
Old Apr 18, 2008 | 05:26 PM
95slvrZ28's Avatar
There is a wheel speed sensor on the back of each of the front hubs, it's the only sensor on there...
Old Apr 21, 2008 | 12:14 AM
Goodfella's Avatar
check the taillights too. if one goes out itll pop a bcm code.
Old Apr 21, 2008 | 09:44 AM
95slvrZ28's Avatar
I've had a tail light go out and the only way I knew was because someone told me...and that's not going to make the ABS inop light come one...
Old Apr 21, 2008 | 11:38 PM
camaro_burns_all's Avatar
VIP member
ORIGINAL: TEXASMAN1
the sensor is a small black wire that is connected to a metal on the rotors.
maybe this picture will help
http://www.motorcycle-usa.com/photos/IMG_9375c.jpg
Old Apr 22, 2008 | 12:31 PM
95slvrZ28's Avatar
Or this picture...
