abs inop
my abs inop light comes on sometimes but they work fine. what do yall think it is?
RE: abs inop
Probably a wheel speed sensor that is either going bad or has a bad connection. I had that issue for about 6 months before it fixed itself...
RE: abs inop
in my old mustang the ABS light came on alot when my brakes were dangerously low. I dont know if it works the same for camaros, someone else may be able to confirm this
RE: abs inop
so where is the sensor at so i can see if i can fixit?
RE: abs inop
Seeing as they are wheel speed sensors, one would only guess they are near the wheels... :eek:
RE: abs inop
There is a wheel speed sensor on the back of each of the front hubs, it's the only sensor on there...
RE: abs inop
check the taillights too. if one goes out itll pop a bcm code.
RE: abs inop
I've had a tail light go out and the only way I knew was because someone told me...and that's not going to make the ABS inop light come one...
RE: abs inop
ORIGINAL: TEXASMAN1 so where is the sensor at so i can see if i can fixit? maybe this picture will help http://www.motorcycle-usa.com/photos/IMG_9375c.jpg |
RE: abs inop
